Turn signal trouble
I bought a 94 900RR about a month ago and have been making it road worthy. When I bought it all the lights, turn signals, etc.. worked.
Well today I noticed that when I turn the right turn signal on, the front doesnt work and the rear one blinks fast. I checked the bulb up front and checked for voltage and everything is good. I even swapped the signal bulbs from left to right.
When I turn the left signal on, the front works fine, but the rear does something weird. It switches from left to right.
I should mention that the rear turn signals are integrated into the brake lights, the previous owner told me so.
Anybody got any ideas?
I'm going thru thea similarproblem right now, what integrator are you using? It was working, then it stopped. I'm trying to diagnose if it's the integrator or the wiring. I'm at work, so I don't know off hand what mine is.
I have to pass inspection, so I just ripped mine out and am going back to stock.
I had the same problem...and I believe it or not sprayed dielectric cleaner into the switch itself cycled the switch and then WD40. Perfect every since
all the power goes thru that switch
try it...worked for me
ORIGINAL: Ghusar
the
On the lfet grip where your turn signal and high beam are spray cleaner into the switch flood it out and then sprasy WD 40 into it after and that fixed the problem for me
ORIGINAL: ForcedInduction
Huh? Not quite getting what you're trying to say...
Cun0144
Sep 23, 2008 10:04 AM
