Turn signal trouble
Old Apr 10, 2008 | 05:30 PM
ForcedInduction's Avatar
Default Turn signal trouble
I bought a 94 900RR about a month ago and have been making it road worthy. When I bought it all the lights, turn signals, etc.. worked.
Well today I noticed that when I turn the right turn signal on, the front doesnt work and the rear one blinks fast. I checked the bulb up front and checked for voltage and everything is good. I even swapped the signal bulbs from left to right.
When I turn the left signal on, the front works fine, but the rear does something weird. It switches from left to right.
I should mention that the rear turn signals are integrated into the brake lights, the previous owner told me so.
Anybody got any ideas?
Old Apr 10, 2008 | 10:52 PM
stynkmonkey's Avatar
Default RE: Turn signal trouble
Check the wiring to make sure all are connected and go where they are supposed to, seems like a couple wires are going the wrong way.
Old Apr 11, 2008 | 08:51 AM
Manic's Avatar
I'm going thru thea similarproblem right now, what integrator are you using? It was working, then it stopped. I'm trying to diagnose if it's the integrator or the wiring. I'm at work, so I don't know off hand what mine is.
I have to pass inspection, so I just ripped mine out and am going back to stock.
Old Apr 11, 2008 | 11:57 AM
Ghusar's Avatar
I had the same problem...and I believe it or not sprayed dielectric cleaner into the switch itself cycled the switch and then WD40. Perfect every since
all the power goes thru that switch
try it...worked for me
Old Apr 11, 2008 | 03:30 PM
My rear turn signals are the brake lights themselves. When I turn the blinker to the right, the right brake light lights up and vise versa.
Old Apr 11, 2008 | 04:01 PM
ORIGINAL: Ghusar
By saying switch, you mean the turn signal switch?
Old Apr 11, 2008 | 04:16 PM
Ghusar's Avatar
work andthen all of them would come on and then the rear right and left front WTF? I thought
my buddy said try it after I went thru all the wiriong etc.
Old Apr 11, 2008 | 05:07 PM
Huh? Not quite getting what you're trying to say...
Old Apr 11, 2008 | 05:12 PM
Ghusar's Avatar
the
ORIGINAL: ForcedInduction
On the lfet grip where your turn signal and high beam are spray cleaner into the switch flood it out and then sprasy WD 40 into it after and that fixed the problem for me
Old Apr 11, 2008 | 06:16 PM
Yea I just did that and I used electrical grease instead of WD-40 to grease it up and I still have the same problem. I also cleaned a dozen connectors and didnt fix my problem
Wants a CBR
May 18, 2010 08:37 PM
MrBlaze
Aug 17, 2009 02:07 AM
Cun0144
Sep 23, 2008 10:04 AM
Flogger
Jan 27, 2008 12:55 PM
Asmittie84
Dec 16, 2007 12:45 AM
