tricks to removing the wind screen
Old 02-25-2008, 07:47 PM
travhouse3000's Avatar
Default tricks to removing the wind screen
i have a '93 900RR and i was just wondering if anyoneknew anytricks to simplify the removal of the rivets holding the windscreen to the upper fairing?
thanks,
travis
Old 02-25-2008, 07:49 PM
Jeff1980's Avatar
Default RE: tricks to removing the wind screen
They shouldn't be rivits. They should be screws and wellnuts.
Old 02-25-2008, 07:51 PM
so they should just unscrew? how do you grab them to unsrew them?
Old 02-25-2008, 07:57 PM
Jeff1980's Avatar
from the factory they're nylon philips head screws, more often than not they've been replaced with aluminum allen head screws. Yours may be stripped which is why they look like rivits. If they're still the stock nylon ones, they will drill out extremely easily.
Old 02-25-2008, 08:03 PM
i don't know if it was modified but these are definetly not screws thereare about five or six of them lining the bottom of the windscreen. the heads are flat much like small buttons about 5 millimeters in diameter. on the other end are little washer like fasteners.
Old 02-25-2008, 08:10 PM
Jeff1980's Avatar
Yeah, its been modified. There should only be four on the whole thing. Can you post a pic?
Old 02-25-2008, 08:33 PM
sorry, you're right it is only 4 here is apic.
[IMG]local://upfiles/15069/2AB8317FA8C74B618BBEB921CF31CFB4.jpg[/IMG]
Old 02-25-2008, 08:37 PM
here is another shot.
[IMG]local://upfiles/15069/21BFF89986CC454686E9C882FA564B44.jpg[/IMG]
Old 02-26-2008, 05:19 AM
Jeff1980's Avatar
That's weird. They are in the right locations but those deffinately are not stock fasteners. I can't say I've ever seen those before. Sorry I couldn't be of any help.
Old 02-26-2008, 06:49 AM
Well it looks like a nice tidy job..
On another bike I had to change the screen and the previous owner went the pop rivet route and I had to drill them out before moving on.. Amazingly I didnt even have localised warping of the screen or fairing. It certainly took less time than the reinstalation with proper nuts and bolts.
So, if you really must whizz them out, poke a small drill bit through them. I got some nice adonised allen headed "mushroom" bolts that added a touch of bling..
CJ
Quick Reply: tricks to removing the wind screen
