Testing Spark plugs
Old Oct 2, 2006 | 08:03 PM
deek98's Avatar
Default Testing Spark plugs
How do you test spark plugs?
I just changed mine and i think they may have gone bad. There only 2-3 months old with less than 600miles on them.
Maybe my ride eating them up.
How do I know?
I'm just a new .
steve
Old Oct 2, 2006 | 09:06 PM
900rr_Guy's Avatar
Default RE: Testing Spark plugs
What makes you think there going bad. What is it doin to make you think that?
Old Oct 3, 2006 | 03:36 AM
deek98's Avatar
Took them out and they were oily.
I changed them. Bike immediatly ran......for 10-15 minutes. Then boged down and I was back to square one.
Turns over and nothing.
Old Oct 3, 2006 | 11:16 AM
pawel's Avatar
If your sparkplugs are oily than you are getting oil into the cylinders. Changing the sparkplugs wont help. If the bike is somking blue when running than you are burning oil.
Old Oct 7, 2006 | 12:44 AM
hyotaek's Avatar
If brand new (stock size/heat range) plugs are oily after a couple hundred miles, then you have blown piston rings. This is not a beginners job. But first things first:
1)Check oil quality. Old/dirty oil will have low viscosity and will make your bike run like ****. 2)Check for oil around where your headers mount to your exhaust ports on the motor. Any oil will indicate piston ring failure/blow-by(gaps in rings lining up allowing oil to pass through to spark plugs). 3)If it is indeed oil on your plugs, you need new piston rings and maybe piston. Let me know what you find out.
Old Oct 18, 2006 | 02:35 AM
deek98's Avatar
test
baseballkid
Oct 4, 2012 07:48 AM
dj600f4i
Mar 6, 2012 02:55 PM
ljung
F2 Tech
May 19, 2010 01:16 PM
PitbullF4i
Jul 1, 2006 01:01 AM
waz57
Jun 4, 2006 03:13 PM
