tachometer
Old Jun 5, 2006 | 09:17 AM
exupguy's Avatar
Default tachometer
Hi there I have a question about the tach from a 94.
How come there are only 2 wires going to the tach since most tachs normally have 3 wires attached to them?
I'm using the tach for another bike I'm working on (yamaha) and it has 3 wires.
Mike
Old Jun 5, 2006 | 11:20 AM
chrisf's Avatar
Default RE: tachometer
What color wires are you talking about? You should be dealing with quite a bit more than three wiring for you gauge cluster.
--Chris
Old Jun 6, 2006 | 04:31 AM
exupguy's Avatar
hi Chris I'm talking about the tachometer only.It's mounted in the middle of the cluster on most bikes there are 3 wires that hook up to the tachometer from the harness.On the tach for a 93-95 900rr there us 2 wires leading to the actual tach.
Does anyone know if there is an internal connection between the gauges?
I tried to open the instrument panel but the know for the odometer didn't want to come lose????
Does anyone know how the **** is attached?I didn't want to brutalize it since most stuff tends to break when I do something wrong
Mike
Old Jun 6, 2006 | 10:56 PM
chrisf's Avatar
I still don't quit get what you mean. On my 98 loom, I had a big waterproof plug that contained all the wires going into the cluster. My tach uses the yellow/ blue (or is it yellow/green, I forget) feed from the ECU. There are also three grounding wires on my cluster. It took me ages to figure out why my tach wasn't working. I finally traced it to a mislabeled ground.
What does the wiring diagram for the 93-95 say?
--Chris
fuentes2709
Feb 27, 2012 05:33 PM
dewdog
Feb 17, 2010 12:03 PM
Chetsnut
Nov 28, 2009 11:52 PM
tapkutez
May 1, 2009 10:03 AM
Hurricane rider
Oct 15, 2008 01:55 PM
