Swingarm sliders
Swingarm sliders
ok got some swingarm sliders for christmas-
was wondring is there actually a place to mount these on a 1999 CB900RR?
i looked and couldnt find anything?
im debating on just drilling a hole into the swingarm and tapping the hole and just bolting the things on?
is that a good or bad idea? lol?
RE: Swingarm sliders
there is no location on the stock swingarm to mount sliders. What I did was weld a nut into each end of the rear axle, and I thread my spools into them. You can do this because the axle is obviously hollow and as long as you use a TIG welder and are careful you will not disturb the threads that the axle nut goes onto. Honestly though, I have never seen the real need for these spools, because if you go down your going to destroy so much stuff (tail, muffler, pegs) that it seems pointless to try and protect the swingarm. Out of all the parts that would be damaged the swingarm would be the cheapest to replace. They look cool, but I would definetely NOT tap the swingarm simply to accomodate them. There is one other way that I considered doing my install. Take a threaded rod from the hardware store and cut it about and inch short of the overall length of the axle. Then thread one of those threaded rod joiners (basically a long threaded nut) onto both ends of the rod and then thread your spools into that nut. If you meaured correctly the tension caused by tightening down your spools wiill tighten the whole setup, and you will be able to remove it all easily to take the wheel on and off. Also, you could just take a tube with a close ID and tap that to accept a similar bolt to the one that came with your kit. You'll have to play around with either of these ideas if you can't weld. Good luck, hope one of the above works for you.
