Strange misfire when accelerating
Old Apr 5, 2012 | 03:31 PM
gregtutch's Avatar
Default Strange misfire when accelerating
hi just wondering if anyone might have a rough idea about whats going on with my 1999 rrx. i done a full service with new k&n air filter and changed the standard exhaust for a mtc gp race can. now the bike accelerates perfect but if you let off the throttle and then twist back on the throttle the bike stutters a bit almost like running out of fuel just for a second then pulls like a train until i let off the throttle again and back on and little stutter. i am thinking may need a set of jets i know the bike was completely standard when i bought it. any one else have any idea what might be causing this before i go spend £120 on jets cheers all in advance.
Old Apr 17, 2012 | 11:24 AM
slothman's Avatar
If the problem started right after you installed the K&n and exhaust, I would assume that air to fuel ratio is off a bit. I would install some new jets (just one size up) and see if that helps!
Old Sep 2, 2012 | 11:59 AM
gpgold's Avatar
This is most likely a jet issue. Your airfilter and zorst upgrades have pretty much made your jets insufficient. Try installing a stage 1 Dynajet kit. This should smoothen things out a lot...
thecbrkid
F2 Tech
May 22, 2012 07:27 AM
95teggy
Apr 28, 2011 02:14 PM
Cryo
May 29, 2008 01:28 PM
oliversta
May 16, 2008 04:46 PM
BurningInFlames
Aug 18, 2006 07:07 AM
