steering head
Old Oct 20, 2008 | 09:24 AM
old drooler's Avatar
Default steering head
i have a clunking in front end-when front brake applied and bars pushedsteering head bearings?
Old Oct 20, 2008 | 12:13 PM
peg grinder's Avatar
Default RE: steering head
They have floating calipers too. But yeah check your steering stem. Take the top triple off,you can't just tighten the top nut.
Old Oct 20, 2008 | 04:09 PM
can you tighten the steering head without re-packing and disasembling the whole stem?
Old Oct 20, 2008 | 04:45 PM
Yeah
Old Oct 20, 2008 | 05:36 PM
Thanks grinder.I have a 97 like the one you are parting out.Its pretty mint,8000 miles.I did some wheelies on it and now notice a good clunk in the front.Hope i can just tighten up the adjuster nut.
Old Oct 20, 2008 | 06:08 PM
Tighten it all. Every nut and bolt on your frontend.
Old Oct 20, 2008 | 07:41 PM
jason954's Avatar
personally I would grease the bearings/races real well too. Then snug it up. If you've never done this before, don't over-tighten the lower stem nut. It doesn't take much, like 7 foot lbs. It's easier to do if you remove your front wheel and maybe your forks too, so you can feel the upper clamp movement. hope this helps. jd
p8ddy
F2 Tech
Apr 29, 2010 08:30 PM
Jaybird180
Jul 20, 2008 02:22 PM
Shadow
May 30, 2008 09:27 AM
GILL
Feb 27, 2008 10:11 PM
9fiddyfo
Jan 21, 2006 04:15 PM
