safety switch w/the clutch lever???????????
Old 08-31-2008, 09:23 PM
rons93rr's Avatar
Default safety switch w/the clutch lever???????????
does anyone know if there is a safety switch for the clutch lever? i already know that my switch for my side stand switch is bad, so i just start my bike in neutral every time. there are times that the bike will not start when in neutral so i then need to hold the clutch lever in to get it started. i was just curious to see if this is caused from something else other than the side stand switch.
thanks, ron
Old 09-01-2008, 07:52 PM
Default RE: safety switch w/the clutch lever???????????
The Clymer wiring diagram (pg. 514 if you have the manual) does show a two-contact clutch switch. One wire goes to the starter relay (which is directly wired to the main fuse) and the other wire goes to the side stand switch. Following the wiring harness from either of those points should lead you to it. A lot of people bypass the stand switch, guess you could just as easily bypass both of them. Hope this helps.
Old 09-01-2008, 10:25 PM
rons93rr's Avatar
thanks alot i'll check it out. these bikes have more safety's than i know what to do with.
macka_moose
11-10-2012 02:56 AM
hurricane_cbr87
10-31-2009 01:04 PM
stunter2boy79
06-17-2007 12:35 AM
bentf3
09-07-2006 03:41 PM
Quick Reply: safety switch w/the clutch lever???????????
