Radiator fan toggle switch???
Old Feb 22, 2011 | 12:10 AM
banthony45's Avatar
Lightbulb Radiator fan toggle switch???
Hey guys I have been trying to put a bypass toggle on the radiator fan for my 93 cbr900rr.
I assumed it would be similar as some of the newer model cbr's but when I hook a wire to the fan fuse wire and the negetive battery cable I keep blowing main fuses and fan fuses.
Any help will be greatly appreciated!
Old Feb 22, 2011 | 04:04 AM
Big Gaz's Avatar
ok i did this to mine and it was really easy. you need a standard on/off switch ( which i assume you have ). take one wire from the switch and ground it on the frame or fairing mount. with the other splice it into the temp sensor ( single wire sender at bottom of radiator on the left ) turn the power on flick the switch and the fan should start up.
Basically with this your by-passing the switch hitting the temp and grounding out to start the fan and grounding it out any time you want it on.
Old Feb 22, 2011 | 06:54 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
??? That sounds like a dead short.
The way it works on newer bikes is you find the ground wire that goes to your fan relay. Then you ADD another ground wire that goes to the same location on the relay and run it through an on/off switch. Switch the added ground wire, not the +12V or the ground wire that's already there.
Doing it this way lets you turn the fan on manually whenever you want but it will still come on when the temp gets high enough to turn on automatically, even if the switch is off. You're not bypassing anything this way or defeating the automatic fan operation.
Old Feb 22, 2011 | 07:10 AM
bambam's Avatar
+1 .. thats whats up , it would suck to forget to turn yer fan on and burn up yer bike.
Old Feb 23, 2011 | 04:17 AM
Big Gaz's Avatar
ok sorry i mis-quoted my self.
By splicing into the wire your adding a wire not removing the normal fan operation. the temp sensor still operates the fan just as normal, you just get the option to turn it on earlier or longer with the switch
pipedcbr
Mar 10, 2012 01:07 AM
dagg92
Feb 11, 2012 12:53 AM
mystro2005
Sep 20, 2007 06:10 PM
jeffrimerman
Sep 21, 2005 09:29 PM
Ntense
Mar 23, 2005 02:30 AM
