Plugs keep fouling out
Old 08-11-2007, 01:41 AM
CBR900RR_JAPAN's Avatar
Default Plugs keep fouling out
I have a 99 CBR900RR. It seams my plugs keep fouling out. I can replace the plugs, and bike will run great for about a week or two. Then after that, they get fouled out again. I think the cyl. is number 1 and number 3 that keep getting fouled...any suggestions please.
Thanks
Old 08-12-2007, 02:38 PM
Default RE: Plugs keep fouling out
sounds like a bad coil since its 1&3 they both run off number one coil.....might be going bad and it might be bad grounds on the coil i would start there... What about the carbs too??? look at the boots where the carbs mount to the motor does it look like it wet,black,or damp around the boot that would mean the carbs are causing the problem....
Old 08-12-2007, 04:06 PM
thanks alot, that will give me a starting place. Appriciate the response.
Old 08-16-2007, 09:53 AM
Also make sure you always get the bike upto @ least a 120 degrees every time you start it
Old 08-17-2007, 04:55 PM
What if it is wet around the boot for the carbs!?!? theen what!??!?
marstenb
04-23-2009 01:09 PM
Dj_Squatch
02-26-2008 09:06 PM
sportracer07
11-10-2007 12:25 PM
92cbr900
08-27-2007 12:29 PM
02-18-2005 11:41 PM
Quick Reply: Plugs keep fouling out
