Oil pressure sensor switch bleeds a little oil
Old May 22, 2017 | 04:31 AM
alalainaa's Avatar
Default Oil pressure sensor switch bleeds a little oil
Hello
My CBR900RR does bleed a little oil if I diagnosed right, from oil pressure sensor switch. Must I hurry to replace it, or should I just check time to time if bleeding gets worse. I cleaned that already and planning to check once in a while if it does not produce harder bleeding. Or should I just open it (of course the oil is drained first) and check if there is broken seal? The oil pressure sensor switch does not seem to be like it could bleed oil throug, so the problem might be the seal?
From link you see my image of the opss.
View this post on Instagram
Or is this rubber protected item in my pic right part. I didn't find an exact expoded pic of that part of engine easily.
Old May 22, 2017 | 09:28 AM
Conrice's Avatar
Is it coming from the threads?
Old May 22, 2017 | 10:34 AM
74demon's Avatar
If it's leaking at all, it won't get any better. It could get much worse, and quickly. Replace it..... I don't need to tell you what happens when oil leaks in front of your rear tire, do I?
CBEN
Mar 13, 2011 06:22 PM
jondevos
Jan 20, 2010 02:21 PM
sco7tys
Mar 27, 2008 06:41 PM
blas32
Nov 27, 2007 01:51 PM
liljoec
Jul 14, 2006 12:35 AM
