oil?
Old Jun 14, 2006 | 03:35 AM
66droptop's Avatar
Default RE: oil?
Correct. It's the lowest part of the bike. Look at the picture below:
Your bike will look a little bit different, but this is the best I can do. Obviously you lack the turbo, and you'll have an oil cooler between the oil filter and the engine block. The black thing is the oil filter. It may come in different colors, but it will be that same size, shape, and location. The red & blue thing WILL NOT be on your bike (it's the oil return line for the turbo), but what it is connected to is the front of the oil pan (the light gray aluminum thing it is connected to).
Go check out Chapter 4, page 1 of this link: http://www.rrzone.com/downloads/96-9...hop_Manual.pdf
It's the Honda service manual for our bikes. 3.8 quarts, since you're changing the filter too. 10w40.
So go pick up 4 quarts (they're sold in 1 quart each, generally) of 10w40 MOTORCYCLE SPECIFIC oil. It has to say motorcycle on the label somewhere, and not two-stroke motorcycle either. You've got a four stroke. If it just says motorcycle and 10w40, you're good to go. Any brand, since it's all about the same. They all have to meet the same SAE (Society of Automotive Engineers) testing standards.
Old Jun 14, 2006 | 09:47 AM
TwistedCBR's Avatar
Default RE: oil?
lol i know a bit about vehicle mechanics but non about motorcycle and i know partially flows together but i never changed my oil myself...just didnt want to screw anything up but seems simple enough. Now i could swear i saw the oil filter in the front of the bike behind the headers...soemthing esle?
Old Jun 14, 2006 | 03:19 PM
66droptop's Avatar
Default RE: oil?
ORIGINAL: TwistedCBR
That's where it is. Filter is in front, oil drain plug is on the bottom, back by the kickstand. Just looks like a bolt. I think it's like 15mm. Whatever it is, it's definitely bigger than those little ones holding the oil pan on (those are 6mm I think). Just find the big gold colored bolt on the underside of the oil pan, and you've got it.
