No Spark
Old Apr 18, 2022 | 09:06 AM
  #21
theproc's Avatar
the tester on 20k ohms i got 0.47
Old Apr 18, 2022 | 09:16 AM
  #22
cbrbike's Avatar
ok. so it's 470 ohms and the reading is fine.
so far we have tested
12v at both ignition coils - OK
12V at CDI - OK
CDI ground - OK
continuity between pulse generator and CDI - OK
pulse generator resistance - OK
i think the bike is in neutral already. so can you test the continuity in between Light Green wire at CDI socket and the battery negative.
Old Apr 18, 2022 | 09:45 AM
  #23
theproc's Avatar
Yeah just tested it light green to ground okay
Old Apr 18, 2022 | 09:51 AM
  #24
theproc's Avatar
This is the one in mine
Old Apr 18, 2022 | 09:58 AM
  #25
cbrbike's Avatar
ok. we have checked all necessary paths i guess.
you may check this too but it's unlikely to go bad both coil connections at once.
continuity between Blue/Yellow at ignition coil and Blue/Yellow at CDI socket
continuity between Yellow/Blue at ignition coil and Yellow/Blue at CDI socket
i think its either the pulse generatoe or the CDI unit itself. we need to have a peak voltage adapter or a multimeter capable of measuring peaks to test them 100%.
but for instance can you put it in to 1st gear, pull the clutch in, side stand up and then start the bike just to see if it gets spark.
Old Aug 16, 2023 | 10:57 PM
  #26
Sims88's Avatar
Default Same problem
Originally Posted by theproc
Well up and at it and there is 12 v at the coil wires and the kill switch works zero volts when off and 12 v when in the run postion is there a test i can do on the cdi
I have a CBR1000F Hurricane that's doin the same thing , except for mine is losing voltage from the battery to the coils, it drops from whatever it is at the battery by around 3 volts for example if my battery is at 12.5 volts i have around 10.5 at the coils , any idea's ?
Old Aug 17, 2023 | 07:03 PM
  #27
dannoxyz's Avatar
Sound like corroded terminals in connectors.
Can measure after each connector to see particular one that's at fault.
Then squirt it with electronics contact-cleaner (DeOxit or OxGard).
Old Aug 17, 2023 | 09:45 PM
  #28
Sims88's Avatar
Right , that's what I've been doin today and to my surprise and idk why I'd be surprised at all cause it's just my luck , now the ole girl still isn't sparking while turnin it over , but after a minute or so it'll start sparking without doin anything but having the ignition and kill switch on.... lmao I'm about ready to pull what little bit of hair I have left out...lol
Old Aug 17, 2023 | 11:21 PM
  #29
dannoxyz's Avatar
If you've confirmed no voltage-drop on way to coils, then it's defective ignition-unit.
Old Aug 18, 2023 | 01:42 AM
  #30
Sims88's Avatar
There is a 3.5 to 4 volt drop at the coils and at the spark box , and now it's doin somethin that I've never seen before... it's sparking on it's own with only the ignition and kill switch turned on , but not while spinning the engine over... I'm stumped !!
