Need a small bit of help with my 97.
Well I bought my 97 CBR900RR. It had a bit of starting problems when I bought it, but I got everything dialed in and it sould start perfectly fine, most of the time without the use of the choke. I took it out for a ride one day and it died on me after a block in a half. Found out a wire on the harnes burnt through at the rectifier, so I replaced both the rectifier and harness. Now it won't attempt to start from the switch. Everything turns when I cross the bolts at the fuse, any idea what might be the cause of this problem. I plugged everything up the way the previous harness was, I am just completely baffled at this.
EDIT: All the lights on the cluster come on except for the nuetral and oil pressure, if that helps.
