Need info. 3 questions?
Old Dec 13, 2012 | 04:02 PM
webfootf3's Avatar
Default Need info. 3 questions?
1) is the sprocket hub on a 900 fireblade identical to the f3 cbr 600?
2) do they use the same diameter rear axe?
3) is the center hub on the fireblade wheel identical as the f3, but just the rim is wider?
i presently have and f3 rear rim on my custom race bike and looking a wider rim 5.5 inch, without to many alterations
webfootf3
Old Dec 29, 2012 | 02:04 PM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Default 6 spoke wheels
Originally Posted by webfootf3
1) is the sprocket hub on a 900 fireblade identical to the f3 cbr 600? Yes.
2) do they use the same diameter rear axe? Yes
Almost 600 F3 slightly narrower but can be an easy interchange, just spacers. Early RC51 is 6.00", SP1 00-01 and are same 6 spoke pattern as the 900RR/600F3, SP2 RC51 02+ later are 5 spoke, both SP1/2 use larger axles than 900RR/600F3 but the sprocket offset is different. Just in case you needed to know and can be made to work with a sleeve if it fits within the swingarm width alotted.
I presently have and f3 rear rim on my custom race bike and looking a wider rim 5.5 inch, without to many alterations.
The 900RR is a good choice.
webfootf3
Good Luck
MaxTO
May 16, 2012 07:01 PM
vlad
Feb 25, 2011 12:59 PM
x10ded900rr
Jun 5, 2006 09:14 PM
insanearmer
Mar 4, 2006 11:42 PM
