my bike wont start.
fuel filter is inside the tank- it's more like a screen. if you take a wrench and loosen the large nut to remove the petcock, it will be around the two inlet tubes.
Also, I'm afraid the large hose on the airbox might not be an issue that's affecting you. I suspect intake plugs/hoses underneath the carbs, or the hoses in between them if it's a california model.
I check those hoses allready i think those going to into one concetor and both go straigh up to the petcock rigth,i take those out allready and they fine ,where is the intake plug/hoses u said underneath the carbs are they arround the starter?or i need to take the whole airbox to look at those hoses?thanks
They are literally less than an inch under the carbs. Sometimes diagnosis is a pain in the butt, but so is an engine that won't run right!!!
update about my bike i put everything back on and samething,the only way it start is open the trothle and when i l;et go it dies,i asked someone at the cycle shop who do job by mobile,he said that it sound my carbs are clogged but still need to look at it first and then make sure what the problem,easy 300bucks so lets see .
welll another bad day,the guy came and try fix my bike,he put some startin spray and starts ok then he said it need the carbs be cleaning so he did it ,after he try to start the engine and he couldn make the bike run at all,it was spitting only and never starts,he check the spark p[lugs and all that and still no luck,he said everything is fine and he think is the brain(the compiuter under the seat)it send the signal on and off,now i got new plugs,new oil,the carbs are cleanand the bike now even dont start even with the trothle open,what u think guys,i suposed to pay 300 he loweer becos he didnt make it run,im wonder waht really its,today he will do reserch about it and see if its the brain or the stator,any sugestion fellas.my battery drain becos we keep trying and trying but it didnt happeneed so what i do next.?thanks
some updates about my bike,now its running,i took it to the shop and they clean the carbs again and they said all the injets were loose becos the other dude who cleand them he didnt tigth them up,also the float bowls were installed wrong so now it runs nice and clean i fell it ,start rigth up after i push the ignition,i drove it and seem stronger than b4.thanks fellasss
Hello @JessiJuju and welcome to the forum. So, carburetors being clogged is a common issue. What is the history on the bike? How long since it's been running properly?
"Cleaning" carbs isn't just spraying carb cleaner through carbs and calling good. Needs complete refurb with disassembly down to every last nut, bolt and individual part. Everything scrubbed with brushes and PEA-based fuel-system cleaner (including hidden secret passages in carb-body). Spray carb-cleaners no longer work due to removal of chlorinated compounds. Then ultrasonic soak everything. Micro soda-blast at very end to clean up. Adjust float levels with final wet-test. Replace all rubbers: fuel-rail O-rings, pilot screw O-rings, float-valves, float-bowl seals, and slide diaphragms if needed. Sync carbs and adjust idle.
Bike ran perfectly fine when leaving showroom floor. It will again when carbs are restored to factory-fresh clean. Different bike model, but all Keihin CV carbs are similar.
That's a lot of work and requires lots of experience and equipment. I just send my carbs to this outfit for refurb every winter when I'm overhauling my race bike. Since I run in stock class, restoring carbs to factory-fresh condition is one of "mods" that make HUGE difference compared to others running with clogged carbs causing stumbling and revving laziness.
https://customcarbservices.com
