motor knock/tapping
Old Jul 1, 2009 | 10:25 PM
captray's Avatar
Default motor knock/tapping
ok so i have 99 900rr. it had a blown motor, i got a new/used motor that was sitting for a yr or so.
swapped that baby in.
Now on idle it sounds ok, but when you give it gas it has a knocking sound coming from the top i believe. This happens in all gears and neutral. What do you guy think this could be. I will try to post a video tomorrow.
Old Jul 2, 2009 | 03:52 PM
Conrice's Avatar
of the bat, i'd try CCT (cam chain tensioner). thats a pretty common problem. if the motor was sitting or has a substantial amount of miles on it, it should be the problem. you can get manual ones on ebay for around $50.
Old Jul 4, 2009 | 11:56 AM
blacktorso's Avatar
hum, my bike makes a light tapping noise but when cold and in nuetral. I wonder if it could be the cam chain tensioner aswell. when the bbike is warm or in gear NO noise. My bike i bought after it was sitting for about a year. I had carbs cleaned and changed oil...
Old Jul 5, 2009 | 10:31 AM
dcb2231's Avatar
how much do you know about the motor that you just put in there? was it a good running motor before you got a hold of it?
Old Jul 6, 2009 | 09:22 AM
captray's Avatar
I know what was told to me. The guy "said" it was a good motor had about 8000 miles or so on it. i turn the crack just to make sure it was not seized but thats as much as i did. I just brought the manual cam tensioner, should be here in a few days. in the mean time i gonna do a compression test and let you know the results, that should give me some more info as to what it may be.
Old Jul 7, 2009 | 11:44 AM
blacktorso's Avatar
my noise was trhe clutch basket...sorry for posting my **** on your thread.
Old Jul 27, 2009 | 05:03 PM
toddmonster's Avatar
check out the valves, or like they said cam chain tentioner
Hondacx2
Jun 4, 2013 08:47 PM
Fuegoblade
Feb 16, 2011 06:45 PM
mofun08
Aug 14, 2008 02:58 AM
2002F4!
Jun 27, 2007 05:28 PM
