Moto GP Shift Pattern
Old Aug 19, 2007 | 10:24 AM
900RRHighlighter's Avatar
Default Moto GP Shift Pattern
Does anybody have a step by step instruction on how to switch the shift pattern?
Old Aug 20, 2007 | 03:09 PM
1badeg's Avatar
Default RE: Moto GP Shift Pattern
If I remember correctly ( I read it somewhere), all you need is a shift lever off of a vfr and you take off the linkage off of you peg assy. and you're done. If I remember where I got that info, I'll let ya know.....but it's pretty simple.
Old Aug 28, 2007 | 12:33 PM
speedextreme's Avatar
Depends on which year 900 you have. My 99, all you need to do is take the shift linkage off of the tranny stud and rotate it 180* and put it back on. You will notice though that the shift rod going back to the lever will hit the frame, so you have two options. 1. You bend the rod around the frame. 2. You install a 929 shifter linkage to the end of the rod on the tranny lug side and it moves the rod out just enough to clear the frame. (This is what I did)
Laters.
Old Aug 29, 2007 | 10:45 AM
I have a 95, so which year VFR shift lever. Then what do you do?
Guernica
Jul 25, 2008 06:05 PM
brancart1
Nov 15, 2007 10:10 PM
rppngears91
Nov 14, 2007 07:24 AM
bladerunner69
Dec 4, 2006 06:25 PM
yashin
Jun 4, 2006 01:52 AM
