how much weight?
RE: how much weight?
I would venture 600 LBS MAX! And you would probably bottom out the rear suspension here and there. The weight limit would depend on how much spring preload you put on the rear end. If you jacked the spring as low as she goes then who knows. The bike will not handle, and you would be better off with a cruiser with anything over 400-450 LBS. The max would be for an emergency. I wonder how the tires would fare? 40PSI isn't much when you distribute all the weight between two of them. Good question, I will do more homework on it later.
