Help! Wheel Swap!!
Old Sep 14, 2006 | 06:16 PM
CbrTuner's Avatar
Default Help! Wheel Swap!!
Hi Everybody,
I am about to buy a set of wheels for a front wheel swap.
Will a 17" 2004 cbr1000rr front wheel match up to a 97 cbr900rr?
Any thoughts?!!
Chris
Old Sep 18, 2006 | 01:43 PM
900RR Puzzle's Avatar
Default RE: Help! Wheel Swap!!
My 97 900RR has a 17" CBR600F3 wheel on it. The guy I bought it from, put it on there. Apparently it's a bolt-on deal with the axel, spacers, and break disks from the 900RR on the F3 wheel. I'm not sure about the CBR1000RR wheel, though.
900RR Puzzle
Old Sep 19, 2006 | 12:24 AM
woody900rr's Avatar
Cbrtuner what year is your 900rr?
In 98/99 900rr the forks where widened at the trees, the f3 rim is not a direct bolt on for 98/99, but is true for years before. Also the 1000rr rim is three spoke where your 900rr is six spoke rims. I run a f3 rim on the front of my 98 900rr, but it took alot of extra work to get it to properly fit ( to be true I dont even thing I got the exact tollerences).
Old Jul 14, 2007 | 12:56 AM
verthigh's Avatar
Knowledge needed! I bought a supposed '96 F3 rim without rotors since I have been reading my '93 900 rotors should bolt on. Well, the hole patternon the900 rotors is wider than the "F3" rim. Is it a fact that the 900 rotors should fit the F3 rim? If not, would the F3 rotors work on the 900?
Old Aug 10, 2007 | 11:38 PM
stynkmonkey's Avatar
What about an F2 rim on a 95 900rr, would that fit as well, as I can see they are all the same size.
Old Aug 12, 2007 | 02:27 PM
900rrjunkie's Avatar
welli can say thisabout the rim swaping thing...........The f-3 rims will work on any 900rr from 93-97-- the rotors from the 900 and the spacers are used and thats the only rim i noo of that will fit without making alot of extra changes on the 900... 98-99 900rr have a different front end on them the forks are wider and it wont fit .. Some suzuki rims do bolt right-up on the 900 but i cant remember what model bikes.... And if i looked at it right the 1000 will not fit the rim is completly different rotors,width,and bolt pattern for the rotors are different ...i wana say it wont fit/well very easy anyways.... but if you have enought time and money im sure you could get any rim on you bike...
Kfcartledge
Oct 20, 2013 07:08 PM
sinister
Jan 26, 2011 01:47 PM
01cbr600
Dec 31, 2010 01:51 AM
powerban
Sep 24, 2008 12:49 AM
Lgr12
Jun 21, 2006 01:06 AM
