Help me !!!! 900rr starting problem
Old Oct 16, 2011 | 01:56 AM
kilraven59's Avatar
Default Help me !!!! 900rr starting problem
[INDENT]I have a 1997 CBR 900rr that i can't get to start. the plugs we're fouled, so i changed them out with very little results. after i changed them out it started once with no problem, then it wouldn't start anymore after that. i also put a new battery in, but it still won't start. when i go to start it i turn the key and gas on and pull the choke. when i push the start button it'll turn over,but then it'll start backfiring and shooting a flame out the pipes. Could someone please give me some suggestions so i can get my bike running ? thanks for your input into this problem !!!!!
Old Oct 16, 2011 | 10:52 AM
exciter900rr's Avatar
I know it sounds stupid, but were your plug wires re-installed in the correct firing order?
Old Oct 16, 2011 | 08:18 PM
kilraven59's Avatar
yes, i changed the plugs one at a time just so i wouldn't have that problem.
Old Oct 16, 2011 | 10:05 PM
Hmmmm. Backfiring while cranking usually means the timing is off. New plugs mean fouling isn't making misfire an option.. Too little gas form clogged jets would make it not fire, then fire…. I'll pick my brains here for a bit…..
Old Oct 16, 2011 | 11:22 PM
estate4life's Avatar
February 2012 ROTM
Giving some details about the history of bike will help members help you..... Did you just purchase bikes. What happened before bike die out? Was it sitting for long time? If so, How long...how did you find out plugs are foul? Did seller advise you? Did you save your old plugs? How they look? Any other related problems?
Old Oct 17, 2011 | 09:07 PM
FLATBLACK740's Avatar
has it sat for a long time? carbs have been cleaned?
Old Oct 18, 2011 | 11:20 AM
kilraven59's Avatar
Default 900RR starting problem
yes, the bike was just purchased recently and it had been sitting for a while, i'm in the process of cleaning the carbs and should know by tomorrow if the jets we're the problem. hopefully that'll solve it, cause i really want to get some good riding in before it gets too cold. and thanks for the input you guys have been giving . maybe tomorrow i'll be able to tell ya'll how good my bike runs.
CBRew900rr
Oct 7, 2013 11:54 PM
gunslinger1274
Mar 25, 2013 06:32 PM
lovemy-cbr
Aug 7, 2009 08:23 AM
dgraviett
Jul 14, 2009 10:59 AM
curt93900
Mar 31, 2009 08:39 PM
