Headlight Question
Old May 4, 2007 | 02:41 AM
bluestanger66's Avatar
Default Headlight Question
my 97 cbr 600 f3 has a 900 rr front end on it, and now since it has 2 headlights, only one works since the f3 only has wiring for one headlight. i dont really want to splice the entire wiring harness to get the second headlight to work, so i was wondering if i could connect the second headlight to a toggle switch? is this possible, and if so do i need to add a fuse or how would i connect the light to a toggle switch? thank you!
Old May 4, 2007 | 04:27 AM
HAVOC's Avatar
Default RE: Headlight Question
hey blue can you please post some pixs ive never seen a f3 with a 900RR front and always wnated to see it back when i had my f3's.
Old May 4, 2007 | 01:39 PM
ya here are some pics. do you know if the toggle switch will work?
Old May 5, 2007 | 01:55 AM
jasonp's Avatar
no dont use a toggle they dont last . just get some wire and do it the right way or you will regret it down the road ! you could even hook it up so one is on all the time and the other comes on with the high beems
Old May 5, 2007 | 08:56 PM
Mad Hatter's Avatar
You could get away with a toggle IF you used a relay. Make sure you get a hefty relay that will handle the juice. The relay will transfer all of the power instead of it running thru the switch which is what causes the switch to fail or burn up. I learned this when I kept burning up switches after I swapped a SuperCoupe fan assembly to my Mustang.
inkredibleg
Apr 9, 2008 09:45 PM
malibuken65
Apr 14, 2007 11:42 PM
fiveoh
Apr 1, 2007 09:06 PM
Tantric
Mar 20, 2007 01:41 PM
spidertron
Apr 29, 2006 02:43 PM
