headlight
Old Aug 19, 2008 | 07:34 PM
speedismyantidrug's Avatar
Default headlight
hey i have a 93 900rr and when the low beam is on only one of them works i was wondering if this is stock or if i can get another high low beam bulb to fix it or if it is in the wiring any advice would be great
Old Aug 19, 2008 | 08:15 PM
MI900RR's Avatar
Default RE: headlight
On low beam, both the headlights are supposed to be on. Way more likely to be a damaged filament in the headlight that isn't coming on on low beams than a wiring issue, but you can check the continuity of the circuit really easily by pulling the plug off the back of the light and checking the terminals with a test light or multimeter. think there is three terminals in the plug, one is ground, one should be hot on low beams, two should be hot on hi beams. Or possibly on high beams there is still only one hot terminal, but it is the opposite terminal that is hot on low beams.
Old Aug 20, 2008 | 08:34 AM
exz5string's Avatar
yea, check the connection, maybe the bulb in the second is burnt out? mine was miswired from the guy I bought it from, had both lights for lows but no hi at all, he just cut the damn wires. but both lights should always be on, lo or hi.
cmartino88
Aug 1, 2012 06:39 AM
papa wheelie
Jul 20, 2011 11:16 AM
Davidth93
Jul 16, 2009 12:22 AM
cyber00677
Aug 3, 2007 03:57 PM
