Giving her a make over!
#142
Since our bikes are carbureted I can only guess they might need little adjustment.I haven't done mine yet. I will be re-syncing them and making small adjustments after I get it back on its own two wheels.
The times I have taken it out I haven't seen any change in how the bike performs..but mine still needs work keep in mind I got it after it sat for three years.
#143
I talked to my shop about syncing the carbs. They looked at it has as something you do if the bike isnt running well. People on here talk about syncing carbs to squeeze out a little extra performance. Like a small tweek. The guys at the shop talked about it like it was something you'd know you would need done.
How would someone know if my bike needs to be tweeked slightly? Im not concerned about it running right, I want it to be running great.
I dont know if I am conveying well what i mean
#144
#145
So I will know if I need it done after I cut my pipe then?
#146
its a general things... even with fi bikes they "recommend" you get a power commander bc you added a slip on
just like the "recommend" you rejet after a exhaust....
by but thats going from a stock very restricting pipe to a slip on...
now going to shorten your slip on isnt going to change how the bike runs drastically enough to where you should notice or need a rejet
#147
Yes you will. But if you are having them synced now then you wont need to do it again. It has to do with the vacume pressure with the darn once they are synced you should be good for a while unless you take off your carbs and work on or seperate them. This is from.my understanding from talking with a friend who owns his own shop.
#148
#149
#150
