front end wobble
Old Aug 9, 2008 | 07:44 AM
kiai's Avatar
Default front end wobble
hello I've a 97rr and when I accelrate hard the front end wobbles it doesn't happen at slow speeds or even high speeds it only happens when I really accelrate hard with fully open throttle I rarely notice it around the city any idea what is the problem wheel bearings seems to be ok
Old Aug 10, 2008 | 04:34 PM
FastJetta97's Avatar
Default RE: front end wobble
could be the front wheel needs to be balanced again... or something in the forks...
do you have a stabilizer.... if not that could do it too.... they are very helpful...
Old Aug 10, 2008 | 05:43 PM
MT Wallet's Avatar
What about your steering head bearings? Maybe they are worn and need to be replaced?
Old Aug 10, 2008 | 08:29 PM
dinez74's Avatar
I can even notice the motogp bike's front wobble when they accelerate hard......
I believe the hard acceleration causing the front to uplift when all the load transfered to rear. Unbalanced geometry. I would worry if the front just wobbling at any speeds.
Old Aug 11, 2008 | 07:43 AM
kiai's Avatar
dinez74 I know the kind of wobble ur talking about specially coming out of turns and being hard on the throttle but this just feels diffrent
Old Aug 11, 2008 | 09:24 PM
dinez74's Avatar
Try to replace the wheel bearings first, that won't cost much. What about the tire? Still in good condition?
Old Aug 12, 2008 | 11:27 AM
lonewolfcbr's Avatar
check to see if you can make it wobble yourself li.ke this....lock your steering with your key, get down low with the front tire and grab it at the front...pull it till the steering lock won't let it go any further...then give it some tugs...so if anything is moving...when my wheel bearings went bad i was able to do this
DANE-GER
Apr 13, 2011 06:03 AM
trackjunkie08
Sep 4, 2009 09:13 PM
nrok2118
Aug 9, 2007 03:27 PM
sweetbro
May 3, 2007 12:45 AM
forx
Mar 11, 2007 10:28 AM
