front end wobble
front end wobble
hello I've a 97rr and when I accelrate hard the front end wobbles it doesn't happen at slow speeds or even high speeds it only happens when I really accelrate hard with fully open throttle I rarely notice it around the city any idea what is the problem wheel bearings seems to be ok
RE: front end wobble
check to see if you can make it wobble yourself li.ke this....lock your steering with your key, get down low with the front tire and grab it at the front...pull it till the steering lock won't let it go any further...then give it some tugs...so if anything is moving...when my wheel bearings went bad i was able to do this
