a few technical questions??
Old Aug 3, 2011 | 11:20 AM
rdeflayme90's Avatar
Default a few technical questions??
my bike had a little squeek coming from it somewhere sounded like the front only at lower speeds, not highway speeds any ideas???and it has a little motor tick,not too loud but it is there is there anything i can get like an oil addatitive for a bike like they make for cars?? any ideas
thanks for all the responses help and advice, in advance
Old Aug 29, 2011 | 12:28 PM
dbbitt's Avatar
NO that would be bad, The valve are mechanical not hydraulic so adjustments are required but it is not as simple as it sounds best left to someone who has knowledge in removing the cams and adding the proper shims. This adjustments can be done in your garage but require the purchase of a shim kit @ about $100 or if you know exactly the size you can order the individual shim
backwoodsCBR
Dec 5, 2012 02:37 PM
Pops642
Jun 4, 2011 03:35 PM
Aweasel
Sep 9, 2008 07:48 PM
Nismo6RR714
Jun 22, 2007 12:37 AM
nondem
Mar 23, 2006 01:06 PM
