Engine missing and running rough
Just got my bike out of storage and it ran fine before putting it in storage. I always add stabil, turn the fuel off and run all the fuel out of the carbs. I started it upand it runs rough and has a miss from the sound of the exhaust. I thought it might need to be ridden to clear it out but it has not helped. It chugs and chokes when starting from a stop but it does have plenty of power and the miss seems to disappear when I open up the throttle and get the rpms up. I checked the plugs and they're ok. Checked the carbs (as much as I could without pulling them off or apart) and didn't see any sludge or gum. Any ideas? Thanks guys!
Steve
Steve
ORIGINAL: sferrall
...Checked the carbs (as much as I could without pulling them off or apart) and didn't see any sludge or gum...
I'm not going to open a can of worms if I pull the carbs off, am I? I am mechanically inclinded but I've always been afraid of carbs....like I'll lose a part or knock something out of adjustment. Is there a lot to taking them off?
Ok, I took the carbs off but I didn't separate them but I did take off all the covers like the float covers and the ones with the black diaphram looking thing. Everything is really clean. I couldn't find one speck of sludge or gum. I blew air thru everything with a little carb cleaner. All fuel tubes and filter are clear so I guess I'll put them back on and hope for the best. I know I said the plugs looked good but they haven't been replace for over 4 years. SHould I just replace since they're easy to do and I have it all apart? Also,if I do all this and it still misses, what's my next step? Thanks.
This is EXACTLY why you need to run your bike at least once a month during the "off season". You cannot "see" gum or sludge in your tank/carbs. Put some new gas in, plus 1/4 bottle of heat, and run your tank out. If you can, get some "open" runs and get on the throttle.
After that, you should be just fine.
Notto be a dick but, what do you mean you can't see sludge in the carbs, I took them apart and they're totally clean plus I haven't had a problem doing this for the last 8 years I've had the bike. I've done the same thing every year....fill the tank and add stabil, never a problem. Plus the gas is only 4 months old. I'll try your advice but what kind of "heet," the yellow bottle w/menthanol or the red with isopropyl alcohol?
Thanks
Thanks
ORIGINAL: sferrall
Just got my bike out of storage and it ran fine before putting it in storage. I always add stabil, turn the fuel off and run all the fuel out of the carbs. I started it upand it runs rough and has a miss from the sound of the exhaust. I thought it might need to be ridden to clear it out but it has not helped. It chugs and chokes when starting from a stop but it does have plenty of power and the miss seems to disappear when I open up the throttle and get the rpms up. I checked the plugs and they're ok. Checked the carbs (as much as I could without pulling them off or apart) and didn't see any sludge or gum. Any ideas? Thanks guys! if you put stabil in it, then it's going to run rough for a while, after 2 tanks of '93 octane you should be alright.
Steve
Steve
Well, I put it all back together last nite and decided to do the plugs since everything was apart. It runs great today. I don't know what it exactly was. The carbs were immaculate so I'm leaning towards a bad plug since they haven't been replaced for a while. Case closed, I guess.
