Electric starter not working
Old Aug 19, 2024 | 01:06 PM
JacobP's Avatar
Default Electric starter not working
Hi guys!! To get straight to the point, my friend picked up a 95 fireblade. We rebuilt the carbs on it and got it running again, but while I was gone he was messing with it and accidentally spilt something on the starter. The starter stopped turning over. Now, after replacing the (apparently) seized starter, it still will not work. The button appears to do absolutely nothing to the starter but when you flip it to the "on" position, the fuel pump primes. Can anyone point me in the right direction?? Any help is appreciated
Old Aug 19, 2024 | 04:40 PM
rockpool's Avatar
Did you check the starter fuse?
Check there's 12v to the starter when you hit the button?
Did you check the old starter was really seized?
Old Aug 19, 2024 | 05:18 PM
JacobP's Avatar
I did check the starter fuse, and then checked it with a fuse checker. I assume you're talking about the one from the relay?
The old starter was very difficult to turn so we went ahead and bought a new one.
Old Aug 19, 2024 | 05:25 PM
rockpool's Avatar
Next step then is to check you get power to the starter + terminal when you push the switch.
Old Aug 19, 2024 | 06:47 PM
JacobP's Avatar
I'll check that out asap. How would I go about checking the terminal good sir? I apologize for my ignorance, first time with a bike this old.
Old Aug 24, 2024 | 12:33 PM
JacobP's Avatar
I checked it, the ground is good on the starter but I'm not sure how to check the terminal
Old Aug 24, 2024 | 04:29 PM
rockpool's Avatar
Use a multimeter to see if you get 12v at the starter when you hit the switch.
Old Aug 29, 2024 | 10:13 AM
BLK900RR's Avatar
Try eliminating the starter button to see if that's the cause. Run a jumper wire straight to the starter terminal to see if the starter will engage.
Old Sep 2, 2024 | 08:51 AM
rockpool's Avatar
set of jump leads with one end connected to a screwdriver and the other to +ve makes a great high-current probe, just don't drop it into the engine ;-)
Old Sep 2, 2024 | 04:51 PM
JacobP's Avatar
It turned over when we took a pair of jumpers to it. Fuel pump does prime though. Could It be the switch??
