Do I need to torque cylinder-head?
About a year back I had the valves done on my bike. Head was removed and send to an engineering shop. Anyway It's now starting to leak oil at the head gasket on the left and right side of head. Actualy it could have been leaking for a while now because I could never see it under the fairing.
On some cars you have to re-torque the head after a few thousand km. Do you have to do the same on the CBR900 or did the shop just do a bad job and now it's leaking?
(Don't want to remove the full head just for a head gasket)
yes , it should be done in sequense , i beleive from the center out, 47Nm oiled
http://www.fireblades.org/forums/hon...d-torques.html
Anyway, they say in order to get the right torque values you should apply oil to the threads so they will turn smoothly and you get a more accurate torque value. Don't just randomly torque the bolts. You have to follow a pattern or you can warp the head.
Also, they should be done in two stages, not just torque them down all the way the first time. Since yours is already assembled you might be able to skip that part.
Grammar typo lol
Anyway maybe I should just tighten them in the specified sequence with a torque wrench to the write value because to remove them is going to be a major job.
Is it possible to get access to the head bolts by just removing the cam cover without removing the cams cam-chain etc. because in that case I'd rather take it to the shop because I just don't have the time to strip the whole engine right now...
