Completely dead, no start, no lites, no nothing
Old May 31, 2011 | 09:27 PM
sferrall's Avatar
Default Completely dead, no start, no lites, no nothing
Went to start my 95 900 yesterday and it turned over twice strongly and then everything went dead. It completely stopped. I checked all the fuses and they are good. I had the battery tested and it is good. Put on a new VR 2 years ago but I doubt that's the issue. Any ideas?
Old May 31, 2011 | 11:27 PM
hitman510's Avatar
try cleaning the battery connection terminals... it could just be that its not grounding when its on because of so much dirt/ corrosion on the terminal itself.
Old Jun 1, 2011 | 03:35 PM
sferrall's Avatar
There is no dirt nor corrosion on the terminals. The connections are good. That's the first thing I checked
Old Jun 1, 2011 | 03:48 PM
DrAwkwArD's Avatar
Have you checked the relays?
Old Jun 1, 2011 | 04:27 PM
hitman510's Avatar
feel the wires themselves, any bubbles in the wires need to be cut out and replaced
Old Jun 2, 2011 | 10:35 AM
Cognac's Avatar
I had same issue....it was ignition relay (wires behind the key hole were frayed)
Old Jun 3, 2011 | 10:30 PM
900rr_Rookie's Avatar
Stupid question...
You check the master fuse under the seat?
Old Jun 4, 2011 | 10:38 AM
sferrall's Avatar
Feel really dumb but after getting the battery checked a second time it turned out to be junk. I've never had a battery completely die and go to nothing on me while starting a cycle.
Old Jun 4, 2011 | 03:19 PM
MadHattr059's Avatar
Don't feel bad. One of the reasons I keep up on these forums, is to find new symptoms to old problems. There are really not that many things that can go wrong in the sub-systems of even modern motorcycles but there are a million ways they manifest themselves. So you are just contributing to the general pool of knowledge. Doesn't that make you sound so much nobler? ;-)
Ern
Old Aug 27, 2011 | 06:42 PM
testpilot's Avatar
Registered Users
Thumbs up 30 amp fuse under the gas tank
Originally Posted by 900rr_Rookie
Stupid question...
Nice! After recently melting an r/r and the connectors, my dashlights wouldn't even light up. It was the 30amp! I got the r/r (and new wiring harness) from eBay for $50 (includes ship), it's bigger than stock and the wires are a heavier guage. I spliced the new connector into my harness.
WhiteHawk
May 31, 2025 07:11 PM
fatluke_nofx
Mar 20, 2012 07:44 PM
thebuch
Dec 24, 2011 01:22 PM
phishstyx
Dec 3, 2007 01:06 PM
soon2Bturbo
Nov 15, 2007 12:28 PM
