Clutch Spring Torque Spec
Old Feb 22, 2008 | 09:29 PM
devo_3386's Avatar
Default Clutch Spring Torque Spec
I have a '98 900 RR. Is there a torque spec for the clutch spring bolts? I can't find anything in my manual. Thanks
Old Feb 24, 2008 | 02:44 PM
SlavDog's Avatar
Default RE: Clutch Spring Torque Spec
Can you specify a bit better what you need torque setting for? I found: starter clutch bolts, clutch cover bolts, and clutch center nut.
Old Jul 2, 2013 | 02:16 PM
j2smooth30's Avatar
I have a 94 900RR and I need to same torque settings. It's the spring bolts that go around the center nut and the manual doesn't specify. It just says to tighten to specified torque settings but the settings aren't listed.
pugsly1002000
Sep 28, 2012 09:45 PM
xcelerated010026
Jun 3, 2009 08:56 PM
egdcbr600rr
Aug 7, 2008 05:39 PM
Ssaba420
Jun 12, 2006 07:54 AM
delta
Apr 30, 2006 12:21 AM
