Cluster/speedo LED bulb replace on older model bikes
Old 05-16-2012, 11:29 AM
estate4life's Avatar
February 2012 ROTM
Default Cluster/speedo LED bulb replace on older model bikes
Ok members, I understand the newer model RR uses led bulbs in cluster...
My question is have anyone every replace those older (93-99 CBR) model OEM bulbs with newer LED bulb? Are they direct replacement without mod?
Reason I'm asking is because ive change all my F/R signal to LED blinkers...everything wirks great except the cluster signal indicator which flashes when you signal (letting you know your signal is on) it works but flashes very dim. Dim meaning not enough (volt) current to the OEM bulb inside cluster. So I was thinking a LED bulb uses lot less current, so if I replace it with a led bulb, should solve my problem...
Any advice appreciated...Tks!
Old 11-29-2012, 03:47 PM
February 2012 ROTM
bump...anyone?
Old 11-29-2012, 04:05 PM
February 2012 ROTM
Well, I found out the bulb PN# is 34909-KW3-003 for the cluster indicators (signal, high beam, neutral, oil)
The speedo dash is PN#34907-KW3-003
Now I know I can replace these with OEM bulbs, but it'll be nice to go LED on ALL.
I'm thinking like blue or purple dash speedo, just amber indicators....
If no one know, I may need to buy one sample or pull the old one from my bike an then send them to superbrightled.com
There gotta be something out there?
If I found a led ready relay direct fit onto my 94 RR ( which also works with the 1000RR, maybe cluster bulb should fit too?
Old 11-29-2012, 04:17 PM
February 2012 ROTM
Well, at least I found out bulb is a Wedge Base:
http://www.google.com/search?q=34909...iw=320&bih=416
Looks like it's only on the 93-94 cbr900rr
If anyone knows where to buy a led bulb replacement, please chime in...Tks.
Old 11-29-2012, 07:13 PM
Vinman911's Avatar
Member & ROTM AUG 2013
you already had the website. Check them out. I'm going to order some soon for my 95.
LED Lights for Cars | 12v | Super Bright LEDs
Old 11-29-2012, 10:21 PM
February 2012 ROTM
Talking
Sorry, I found out its the other way around:
The PN# is 34909-KW3-003 is T10 wedge base - speedo dash
The PN#34907-KW3-003 is T6.5 wedge base -for the cluster indicators (signal, high beam, neutral, oil)
Keep this in mind when ordering....
Old 11-30-2012, 08:47 AM
jasonchristopher's Avatar
where do you go in that website guys..
is it under misc????
or just sumit the part numbers.. I need to swap them all out too!!
Old 11-30-2012, 10:41 AM
February 2012 ROTM
Hey guys, I just got a respond from Superbrightled.com tech. He suggested a link for the replace of the T10 wedge base bulb. He said to use the 194 type bulb (1 smd). I'll post the link....
As for the T6.5 he's check and let me know later if ok to use the same 194type 1smd bulb
BRB....
Old 11-30-2012, 10:55 AM
February 2012 ROTM
Ok, before I confuse everyone, here is the link to diagram of the 93-94 CBR 900RR speedo, 95-97 may be using the similar bulb, so please check for yourself.
If you look at #1 & #2 below....
#1 is PN#34907-KW3-003 is T6.5 wedge base -
#2 is PN# is 34909-KW3-003 is T10 wedge base -
By looking at the shape of the sockets in the diagram, I need 2pcs #1 (T6.5) , and 7pcs #2 (T10) bulbs.
Superbrightled's tech already recommended the buld for the T10, now I'm waiting for his respond on the T6.5.
I guess we have to figure out what type of LED bulb to use for replacement, since it's different wedge base type (T10 & T6.5 )
http://www.cmsnl.com/honda-cbr900rr-...2.html#results
Old 11-30-2012, 11:00 AM
February 2012 ROTM
Here is the email with SUPERBRIGHTLED's tech support:
Ryan,
Thank you for reply, before ordering, I discover below:
PN#34909-KW3-003 (12V 1.7W H.D) is T10 wedge base.
PN#34907-KW3-003 (12V 1.7W) is T6.5 wedge base.
On my below email, I only indicated the T10 base. Would you recommend the same led bulb (194 type, 1smd) for the other T6.5 base.
Dennis
Sent from my iPhone
On Nov 30, 2012, at 6:12 AM, Ryan Hall <sbl-support2@superbrightleds.com> wrote:
Hello Dennis,
Those are 194 type bulbs. Id suggest something like our 1 smd bulb here :
194 LED Bulb - 1 SMD LED Wedge Base | Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs
Thank You
Ryan Hall
Customer service/Technical support
superbrightleds.com
Quick Reply: Cluster/speedo LED bulb replace on older model bikes
