Change the wiringharness from95 to 96???
Old Mar 28, 2018 | 04:32 AM
markus.attoff's Avatar
Default Change the wiringharness from95 to 96???
HELLO
Hej jag undrar om det går att byta wiring harens en 96 cbr900rr till min 900rr som är en -95
jag ska även byta instrument men det kan jag göra. Så min fråga är..
95:an har en kontakt extra som jag tror går till förgasaren (throttle sensor?) cdi boxen fungerar ju med andra årsmodeller.
Old Mar 28, 2018 | 09:20 AM
EchoWars's Avatar
Google translate:
HELLO
Hi, I wonder if you can change the wiring harness a 96 cbr900rr to my 900rr which is a -95
I'll also change instruments but I can do that. So my question is .. The
95 has a plug-in that I think goes to the carburetor (throttle sensor?) The cdi box works with other year models.
3v1lj03
Aug 25, 2012 07:37 PM
89HurricaneF1
May 7, 2012 09:52 PM
mallen83
F2 Tech
Aug 27, 2011 12:17 AM
michealparks
Feb 10, 2010 12:16 PM
otisdr
Aug 7, 2006 06:51 AM
