can 1993-1994 headlights and fairings be installed on 1995?
yes, they can... but why? The only problem you may or not have is the gauge stay bolt position, the wiring location (fuse box is on the right side for the dual round light front), and you won't have the little light above the headlights. I do recall seeing a guy using a 93-94 gauge stay with a 95... but I may be wrong. As for the lines or looks of the bike, the side fairings match up without problems. The changed the holes and slight look of the fairings after 96 + the tail holes but bolt right up until 98-99. Oh yeah... also the inner panels and inside fairings are different where they bolt up on beneath the headlights. 93-94 had 4 holes and the 95-97 had 2.
Now with all this info... why go backwards on looks when most people go newer look?
