Boggin/Studdering
Maybe it's running too rich...if you tried to rev it up from idle, did the engine stall a bit before the rpm rev up? Did you set the fuel mixture screws below each carbs? it should be turned out according to the manual for best standard setting... but also have to be adjusted according to where you are from sea level. On 98-99 it should be turned out(counter clockwise) - about 2 turns if i'm not mistaken.
Hope this helps, and sorry if i'm wrong
