bike wont start help
Old May 19, 2010 | 09:41 AM
chuck1985's Avatar
Default bike wont start help
i have a 98 cbr 900 bike fell over during the rain last night and now it wont start this morning what could be wrong. just put in brand new spark plugs and fully tuned up and carbs rebuilt. to top it off the left fairing and upper fairing cracked f my life.
Old May 19, 2010 | 02:04 PM
fastspares's Avatar
Hey Chuck
Don't be down fella!
If its was running fine before the 'fall' then its gonna be real simple so don't get carried away doing anything drastic.
Have you checked that there is a spark when you turn it over...? Easy way is to remove the LHS plug cap and put a different plug in it short it out by holding the very end to the frame or a solid bracket? If its sparking OK then a quick check to see if the fuel tap is damaged by the fall? maybe the vacuum pipe has been trapped or damaged? undo the drain screws on each carb to see if the bowls are filling with fuel?
No Spark ? Has the clutch lever switch be damaged ? and check also the side stand switch which are all connected back to the igniter pack and will stop the ignition circuit going live.....
What about the neutral light ? has that suddenly disappeared?
If you've checked all of this then sorry if it sounds obvious
Keep your pecker up!!
Old May 21, 2010 | 09:15 AM
chuck1985's Avatar
it started up now i just need to fiberglass and paint the plastics thanks for the help
willie72
Oct 26, 2022 04:53 PM
aperez18
Feb 19, 2014 11:13 PM
CBRbanas
Mar 3, 2012 11:52 PM
tagger609
Jun 27, 2008 02:09 PM
demonchild
Jan 31, 2008 01:42 AM
