adjusted chain, now rear brake prob.
Old Apr 25, 2008 | 11:41 AM
89ls1's Avatar
Default adjusted chain, now rear brake prob.
So I adjusted my chain cause it was loose as a 2 dollar wh..... anyway now my rear brake does not have the stopping power it used to, the wheel is aligned correctly I checked and rechecked like 5 times. I used to be able to lock up the rear no problem and now I can stand on the rear brake and it wont lock up. Nothing changed but the chain adjustment. Any ideas? Also I bleed the system just for the hell of it and that changed nothing. Maybe I need to adjust the linkage or something?
Old Apr 25, 2008 | 07:16 PM
SpiritRR's Avatar
Default RE: adjusted chain, now rear brake prob.
Maybe you're too far out in the swingarm, just far enough that the caliper's pads aren't able to bite on as much real estate as they used to. If your two-bit 'ho of a chain is that loose, get a new one (and a new sprocket (set)).
Old Apr 25, 2008 | 09:29 PM
dinez74's Avatar
Maybe if your chain is too loose, you can cut out a ring and bring yr wheel much nearer to the swing arm. I'm sure then your issue will be solved.
Old Apr 25, 2008 | 10:03 PM
teddi's Avatar
the grooves on your pads and rotors doesn't match up anymore. give it some time and a new set of grooves should develop. it's like breaking it in again except longer. i would just get new pads.
Old Apr 25, 2008 | 10:34 PM
stynkmonkey's Avatar
But you don't want your rear to lock up anyways. Locked rear means bad news when trail braking.
Old Apr 25, 2008 | 10:43 PM
sas1810's Avatar
sorry to ask, but if only adjusting the back wheel, how do the pads and disc not line up? never had a problem with min at all. i think it may be that the pads are low and the pistons have gone and locked out, or they have glazed over from being too effective.
Old Apr 27, 2008 | 08:04 PM
89ls1's Avatar
There is no problem with the pads and rotor not lining up the caliper are on that bracket which is on the axle so it moves exactly with the wheel. I did replace the pads and rebuilt my calipers all the way around and the front works great but the back just does not have the stopping power it did, I know you dont want to lock it up and I can brake pretty hard with just my rear and not lock up but now I can't lock it up even standing on the damn pedal. Im just giving it some seating time then will mess with it later if it does not get to where I like it again...It still works just not like it used to. Thanks for all ya'lls comments
Old Apr 27, 2008 | 10:22 PM
SpiritRR's Avatar
ORIGINAL: sas1810
Yikes. I could be dumber...but probably not. That's the whole point of the notched slider inside the swingarm, and for running the axle through the caliper's mounting bracket.
*stands in the corner* I'll just be over here with my thumb out of sight, if anyone needs me, which you won't, cause I'm dumber than a rock. Go ahead, ask me how many master links I have on my current drive chain...g'head, ask. [&o]
Old Apr 28, 2008 | 12:10 AM
Ghusar's Avatar
Ok the problem is you cant lock up the rear brake right?
****air in the lines***
Old May 1, 2008 | 06:33 PM
900FighterRR's Avatar
don't want to sound stupid but all it takes is one good fingerprint of greese on the rotor to ruin the bite of the pads. Is there a chance that when you were messing with the adjustment you might have grabbed or touched the rotor with greesy hands? Its good to cover all the bases. Also, its been said already but you really never want the rear to lock up so it may not be a bad thing, i've never tried to lock up mine but I know if takes a lot of pressure to bring mine to a stop on a down hill with just the rear brake. Don't want to seem like I'm assuming your bad mechainci or anything just throwing out some ideas. Good luck
HuskerRed
Apr 30, 2012 09:06 PM
miksane
Aug 19, 2010 05:00 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
snowboarding82
Apr 13, 2008 08:05 PM
mini bagels
Sep 4, 2006 04:31 PM
