97 CBR900, Coolant in oil.. Helpppp
Old Jul 23, 2017 | 11:00 AM
trendsettas's Avatar
Default Jets
install a new jet kit and while your at it, replace the spark plugs also. Make sure you clean the carbs before installing new jet kit. This issue will go away
Old Aug 5, 2017 | 04:38 PM
900rrGuy's Avatar
Originally Posted by mosherj7
Yes i did notice that. I did do a pressure test to see if the internal seal would go, but so far no leaks.. Im leaning towards just picking up a jar of the "Pelletized Stop Leak" It says it "Helps to seal internal, external and coolant-to-oil leaks with coolant applications"
NO.......that stuff causing all kinds of other problems in the cooling system and should only be used as a short term fix like during a rally ride or something just to get it home.
mcastro253
Jul 2, 2012 05:13 PM
__Z__
Feb 2, 2011 01:58 PM
Smokie187
Nov 11, 2010 10:39 AM
deligh8t
Dec 17, 2007 04:17 PM
necio2007
Aug 18, 2007 10:18 PM
