97 CBR 900RR turn signals and headlight?
Old Apr 20, 2007 | 07:06 PM
bluestanger66's Avatar
Default 97 CBR 900RR turn signals and headlight?
i just purchased a 97 cbr 600 with a 900rr front end, and it doesnt have any turn signals on it. are they hard to instal? or would you just leave them off? also do you know where i can find the wiring for the headlight, since only one light works since the 600 only has one headlight. i was told to splice the wire to make both lights work. i didnt know if i needed all new wiring for the headlight or just splice what was connected now. how hard is it to get behind the headlight and do the wiring? thanks for the help! much appreciated!!
Old Apr 21, 2007 | 01:59 AM
HAVOC's Avatar
Default RE: 97 CBR 900RR turn signals and headlight?
can you please post up some pixs ive never seen a f3 with a 9RR conversion
Old Apr 21, 2007 | 03:01 AM
here are some pics, i will get more soon!
Old Apr 22, 2007 | 12:04 AM
900rrjunkie's Avatar
I have led's in the little vent holes and slim turn signals . My turn signals only light up when they are in use. So i had to use led's for the running amber light's. When you bye turn signals make sure they have two wires coming out of them or you will have to do what i did .I used velcro to holdthe led'sin place and spliced it to the turn signal . As for the headlight i also cut the wiring and put the two headlights on hi-beam only . I'm running the right side headlight on low-beam to give it that newerEURO look . You have to get help doing this if your not good at reading electricdiagrams from your ownersmanual .
scoots
Jul 31, 2019 09:54 PM
Acespad3
Mar 25, 2013 11:16 PM
southpole560
F3 Wanted
Nov 21, 2011 05:17 AM
Decepticon42
Apr 14, 2011 03:57 AM
kao600f2
Aug 23, 2008 12:46 PM
