95' vs '96 900rr tech ? on exhuast
Old Apr 18, 2010 | 08:36 PM
fuelmanpat's Avatar
Default 95' vs '96 900rr tech ? on exhuast
i've got a 95' 900rr with a stock exhaust. I want an aftermarket pipe but I find little to fit the 95' year but quite a few for the 96'-99' year. In my search I found full systems to fit yrs 93'-99' but bolt-on's for 93'-95' and 96'-99'. I looked up the parts diagram for both 95' and 96' and they appear the same. My question is if a full system will fit 93'-99' why won't the 96' bolt on fit the 95'??? Any and all comments would be appreciated, thanx
Old Apr 23, 2010 | 07:07 PM
jzanutto's Avatar
I have a Sudco complete system on my 95
Old Aug 31, 2010 | 01:43 PM
fuelmanpat's Avatar
Default update: 95' vs 96' 900rr tech ? on exhaust
I decided to buy a pipe and just modify where needed to make it fit and function. I bought a Yoshimura rs3 bolt on pipe for 96'-99'. I'm happy to say no modification was necessary. The 95' model's bolt up pattern was not changed on the 96' model.
Old Sep 1, 2010 | 02:08 PM
Hondas Rule's Avatar
The bolt pattern is the same, from the pics i've seen only the clocking of the holes is different
Old Sep 9, 2010 | 11:19 AM
fuelmanpat's Avatar
You are correct the pipe does point about 3 to 5 degrees to the right(away from the bike) but it doesn't effect the mounting bracket and still looks pretty good.
David Bradley Terry
May 8, 2014 09:34 AM
Sand.Man
Oct 2, 2010 07:47 AM
BigCat
Nov 10, 2008 01:30 AM
sacbr1000rr
Oct 25, 2008 01:20 PM
