95 CBR900RR fork parts needed!!
Old May 9, 2015 | 12:12 AM
ambeos5's Avatar
ROTM, Oct 2014
Default 95 CBR900RR fork parts needed!!
here we go again with another unforseen problem the Damper adjusters on my bike were seized so of course i tried getting them to break loose again so i could have this adjustment. Which the rod promptly broke off and the adjusters striped out. ive looked on bikebandit and ebay, Bikebandits break down of the front forks dont even show these parts at all just the whole assembley, so if anyone has any suggestions im open mineded. anyone got some bent forks laying around i can buy these parts out of?
Here is some pics so you know what parts im refering to
(above) this is the end of the rod were it is supposed to attach to the adjuster, the spearhead looking end(opposite end) goes into the fork assembly
(above) this is were the rods in the other picture are attached to normally they broke off mine
(above) this is the top side that comes through the top of the fork cap at the triple tree so you can adjust the damper and preload
(above) a picture of the rods that have broken off the adjuster, the spearhead looking ends go into the fork assembley
Old May 9, 2015 | 06:45 AM
Vinman911's Avatar
Member & ROTM AUG 2013
I got you covered. check your email.
Old May 9, 2015 | 02:39 PM
ambeos5's Avatar
ROTM, Oct 2014
Thank you Vinman!!
Old Nov 27, 2020 | 06:13 PM
Rick1979's Avatar
Default Question time
Attachment 27616
Attachment 27617
Attachment 27618
Attachment 27619
hi I hope you don’t mind I have a question for you in the 3rd photo you put up of the adjusters could you please let no if below the O rings in the second recess if one adjuster has a O shaped spring in holding a ball bearing? and the other adjuster has nothing just an empty recess below the O ring I’ve been looking for an answer to this for a long time if you or anyone knows the reasoning to this I’d love to know thanks for your time kindest regards
Marco Marfè
Feb 5, 2016 05:16 AM
ambeos5
May 12, 2015 07:57 PM
alienjoe
Aug 26, 2013 05:50 AM
jfeagin
Feb 14, 2010 06:52 PM
crashkhanman
Oct 12, 2008 10:42 AM
