94 CBR900rr front fairing question, please HELP
Old Jun 1, 2009 | 09:27 PM
dcb2231's Avatar
Default 94 CBR900rr front fairing question, please HELP
I have a 94 cbr900rr with the 2 round headlights in the front. i was wandering if i can convert to the 95-97 front end without a big hassle. i like the look of that front way better. i know i would need the headlight assembly, but is there any other problems i would run into? thanks in advance!!!
Old Jun 2, 2009 | 11:58 AM
exz5string's Avatar
headlight assembly, front fairing, fairing stay, all different from the 94. I also have a '94 and was considering doing the same thing, but I think I'm gonna customize a headlight for it, go for that totally original look.
Old Jun 15, 2009 | 05:42 PM
DMACK's Avatar
Default Swapping a 98-99 front fairing right now
I completed a tail swap about 2 years ago, then bought a house and had a kid brfore finishing off the front end. I am finally getting to it now. I am using a 98-99 upper fairing for the latest look. That is the last year possible to swap without rediculous modifications. As mentioned in an earlier post you need the upper fairing, fairing/ guage support, headlight, fairing stay, inner upper fairings, inner lower fairings, and the V fairing at the bottom to complete the swap. Also you need to mopdify the fairing/guage support to accept the 94 guages as the locating points for the later fairings are in a different position.
I took the 98-99 fairing filled in the center position light, and the holes on the side to make it look even more modern. It should match up with the custom tail nicely. I just got a quote to get it painted. I just need to do a little finish sanding and it will be off to paint by the end of the week.
Here's a couple pics of thetail. I think I have some of the fairing somewhere. I will have to check.
Attached Thumbnails 94 CBR900rr front fairing question, please HELP-sticker-2.jpg   94 CBR900rr front fairing question, please HELP-finished-1.jpg
Old Jul 28, 2010 | 11:12 PM
mavlick's Avatar
what all did you have to do for the tail conversion. I have a 94 cbr900rr and I want to upgrade the tail section to an 07 cbr100rr tail. I was just wondering what you did for the subframe and undertail, or if there where any other mods you had as far as the tail goes?
Old Jul 29, 2010 | 08:54 AM
scutfargas's Avatar
December 2011 ROTM
DMACK, do you have any larger pictures of that tail section? It looks great!
NoMercy28100
May 25, 2013 02:49 AM
BLACKEDOUTf4
Jun 30, 2008 07:31 PM
japanese900rr
Oct 17, 2005 05:41 AM
