93 cbr900rr idle at 2500/4000rpm in neutral
Old May 24, 2011 | 06:10 PM
gigaman1's Avatar
Default 93 cbr900rr idle at 2500/4000rpm in neutral
Hey guys...
so Recently had the bike running but found the battery was dieing due to a faulty regulator rectifier. we didnt get much testing out of it and I bought another regulator and after installing it noticed the idle rpm was 2500, I finally got to drive it around the neighbor hood some and when I would clutch it the bike would idle at 4000 rpm.
Any suggestions on this?
Also I noticed after riding for a while, I got to my house and turned the bike off leaving the key on and the fan continued to run, I let it run for a couple minutes figuring it was just cooling the fluids in the bike, does this go off on its own? is it safe to just turn the key off while the bike is off and fan is running?
this is my first big boy bike lol so be easy on me if these are dumb questions.
Thanks!!
Old May 25, 2011 | 08:42 AM
exz5string's Avatar
Have you tried to turn down the idle adjustment?
As far as the fan, I always just switch the key off, never turn the bike off at the control. The fan is trying to help keep everything cool since the engine warmed it up, if the engine isn't running the fan doesn't need to be on, it won't get any hotter. Go ahead and switch the key off, I wouldn't worry about it.
Old May 25, 2011 | 03:39 PM
900rr_Rookie's Avatar
Does the idle vary while stopped? And have you had the carbs off yet?. With mine I had an old in-tank filter that was breaking up and slowing clogging up my pilot jets. I'm not saying this is the case with yours, but if just one jet is clogged, the bike's idle will just not be right.
Old May 25, 2011 | 09:25 PM
gigaman1's Avatar
yeah the carbs were off, had to replace the orings that go on the T in between the carbs, the carbs were jetted before, initially the bike ran ok for a few minutes but after running more the idle seems to go up pretty high, the adjustment screw is locked so we gotta pull the tank again to get to the screw.
also noticed the speed gauge isnt working, we disconnected the cable and will see if it spins I guess when we ride it.
Old May 26, 2011 | 11:20 AM
the_transporter's Avatar
Next time you have the carbs off, take the float bowls off and remove both the pilot and main jets. And hold them up to the light. If any of the small holes that run down the sides are clogged, then it can cause the idle to run up and down. Just simply blow each one out. And also check each float, making sure it is free to travel. As that also meters your gas flow.
btw, am same guy as 900rr rookie. just signed in with facebook...
Old May 26, 2011 | 08:55 PM
gigaman1's Avatar
Thanks guys the idle screw was locked up on max idle after fixing that the idle is right and now I can adjust it I will check the carbs next time anyways. So far so good, pics to come soon the cable for speedometer isn't spinning we will fix that next, bike is running real good and I just got my new helmet today!
Old May 27, 2011 | 04:43 PM
SGTSKiP's Avatar
Im glad that you found out the fix before taking the Bike and $300 to a shop
Ride it, sent pics of the bike and your new Skull Cap
Tupp
Dec 30, 2015 11:07 AM
jackusdayus
Dec 9, 2012 04:58 AM
Deathrace2010
Jan 19, 2012 09:37 AM
isisdawn
Apr 27, 2009 12:02 AM
juno
Apr 24, 2009 01:04 PM
