929 rear wheel on a 900??? how to?
Bolts right in. All I had to do is use the axle shaft and hub off the 929, the chain centers perfect and it has thew same distance between the swing arm. The only mood you have to make is dremel out the swing arm to fit the larger axle shaft and use every thing from a 929. Johnny
i more wanted it to match my front wheel 929 wheel. this bike should be bad *** when im done its got 929 triple clamps, 929front and rear wheels, its got 03 rc51 fork tubes w/ rc51 calipers and rotors, withe vortex clipons. and more to come but that the suspenion can i use a 929 rear shock??? i have one some where...
berga
F2 Tech
Mar 25, 2010 09:11 PM
