900rr exhaust compatibility
RE: 900rr exhaust compatibility
the 929 or 954 wont work due to the mid pipe. If you change the entire exhaust no problem, but if you just want to change the can, it's the bolt pattern that's the problem.
The 93-95s are the same, 96-99s are the same. On the 93-95s if you look at the 3 bolts on the can they form a triangle, one bolt is at the top( I think). On the 96-99s one bolt is at the bottom. The bolt pattern is exactly the same just rotated 180 degrees. If you mount a later year can, the exhaust tip points in the wrong direction. You can get the mid pipe cut, rotated and re-welded then use the later cans.
You can always get a completely new mid pipe, which should come with the new slip on end with springs and use any new modern pipe you want, buit that's pricey. I just kept looking on EBAY until I found a carbon fiber yosh for my year (94), and it was $140 shipped if I recall. You can get aluminum ones for under $100.
