1998 900rr high beams and low beam?
Old Feb 22, 2009 | 06:38 PM
NJCBR900rr's Avatar
Default 1998 900rr high beams and low beam?
Where is the high/low swithch??
Old Feb 22, 2009 | 09:20 PM
camaropower's Avatar
If its similar to my 95 900rr, it is on the left clip on by the clutch perch
Old Feb 23, 2009 | 12:05 PM
jerbear's Avatar
yup left above the blinkers its a thumb switch
Old Feb 23, 2009 | 12:36 PM
NJCBR900rr's Avatar
ohhhh, so I guess my low beams dont work. Thought that was the on off swithch. Guess there is no point in having low beams anyway.
Old Feb 24, 2009 | 11:05 AM
jerbear's Avatar
try toggling your switch. On my 98 900rr if i switch to high beams the lights sometime go out and i have to toggle the switch back and fourth. Same is true if i go from high to low. Also I could believe the bulbs are actually two filaments so you could just have the low beam filaments burned out in your headlights.
Old Feb 25, 2009 | 06:24 PM
Yes they are dual filaments, I had high beams but not low, replaced the bulbs and all is good
ttemby
Apr 3, 2012 07:13 PM
Turbulenz
Oct 31, 2010 06:52 PM
buknoy
Jul 1, 2009 06:18 PM
skeeter6103
May 20, 2009 06:07 AM
stephen4785
Mar 9, 2005 09:38 PM
