WTF ???
I took the bike out of a cool/cold garage. Rode it down about 4 blocks and was going to make a left turn at about 15-20mph and BAM the dang bike slide out from under me.
I scraped the hell out of the fairings, handle bar, elbows, and took a 1/4 chunk of fat out of my knee cap.
Why did it slip out from under me? I haven't done anything different today than any other day. There was no sand nor gravel nor debris on the road.
Only difference is, today I was trying out the new Harley Davidson boots I ordered and the weather was a bit chilly.
I was having trouble fitting the boots underneath the foot clutch to shift so I was semi distracted but that's about it.
Do I have to prep the bike out first or something? I remember reading something about using a hair dryer/blower on the tires to warm them up?
[IMG]local://upfiles/19431/0E3EFFE6CB414A3291F8B17C691F3751.jpg[/IMG]
Depending on how cold it was out, and if you're the type of person to take moderately slow turns at a lean, that could all play a role in your tire slipping out. Or maybe you had some grease or somethin on your tire. Or perhaps there was an accident there the other night, and some oil soaked into the pavement, or coolant or who knows lol.
Thank god I'm such a coward on bike. I had my helmet on and gloves too. I had to cut the jean to show the bruise there.
At first all I could think of was, WOW it doesn't hurt....my head slamming into the street...then I was like omg I hope no one runs me over.
Then the pain from the knee and elbows kicked in.
The helmet really works
15-20 MPH isn't anything to get worked up about tire heat. chances are you hit some tar or sand. What's you're pressures at? tire manufacture/model?
unless you've modified the rear end somehow that's what i see... did you replace a wheel recently?
HAHAHAHAHA, heating the tire with a hair drier! Jesus what will they think up next?!!
did you down shift in the trun, I have got my back end to drift out alittle durning turns a few times when i first got my bike because i down shifted in the turn. I never went down but it was pretty hot and i had been rideing around. I could see that combined with a slick road and cold tires adding up to a low side.
Besides the lowering kit, tire pressure and all is factory default.
Haven't looked at it yet. All I remember is leaning into the turn and BAM...should I get up or should I rest a bit. Best get up before I get run over.
Heh yea from now on will definately do a mile or so before doing any sharp turns/leans.
