wont start?? help...
Old Jun 13, 2007 | 03:54 AM
four.six's Avatar
Default wont start?? help...
i got a 06 CBR 600 RR. when i turn the key to the on position, the display does not come up. when i try to start it, i hear clicking under the seat. battery tested good. replaced the magnetic switch assembly next to the battery cause thats where the clicking is coming from (80 bucks). turned key to on position, and got the display the first time. but after that, no display. and still clicks when i try and start it.. please HELP! i'm supposed to take it to the dealer on the 19th, but i really would rather save the money and fix it myself... thanks.
Old Jun 13, 2007 | 03:58 AM
CBRFREEK's Avatar
Default RE: wont start?? help...
Check your fuses...
What did u do to it when it was running?..Did you add on?...
Old Jun 13, 2007 | 04:08 AM
four.six's Avatar
no add ons. all stock. it just all the sudden wouldn't start.
checked the fuses under the left faring, all good. checked the fuse on the switch assembly, and it was good. are there any other fuses that i am not aware of?
Old Jun 13, 2007 | 08:40 AM
MADMN's Avatar
you need a new battery they only last a couple of years at best
so many people make the same post its getting boring
Old Jun 15, 2007 | 10:49 PM
four.six's Avatar
replaced battery already, but it only tested at 12v. is that right? thought it was supposed to be 14??
Old Jun 16, 2007 | 12:49 PM
alekinci's Avatar
Most batteries are over 12.6+v if they are good. 12v is fine too.
I would check the connections from instrument panel to harness and harness to the ECM.
It dont think its the fuse. Possible that it can be a relay, but for some reason I think it might be a wiring issue. It a very common problem on bikes < its not limited just to honda.
Old Jun 17, 2007 | 03:17 AM
four.six's Avatar
tests 12.4V..... what do i need to do to trouble shoot a relay? what is a relay? and could it be the start button on the handle bar?
Old Jun 17, 2007 | 03:29 AM
doncollins's Avatar
Retired Administrator
I just had this happen to me becuase I worked on my turn signals one day and ran the battery down. Same clicking noise. I hate to keep repeating this and I know you said you bought a new battery, but did you let the battery charge up slowly over night? Put it on a slow charge for several hours and see what happens. I was getting pissed and thought I killed the battery and gave up. I left on charge over night and started looking to order a battery. Came back the next day, took the charger off and it started like new... Saved me $$$ The cheapest battery I found was $60 for off brand shipped, locals wanted up to $189!!
Old Jun 17, 2007 | 04:57 AM
taymax14's Avatar
I second that. I had this happen with my bike. charge it slowly.
Old Jun 17, 2007 | 12:58 PM
doncollins's Avatar
And when we say charge it slowly... we mean use a 1 or 1.5 amp charge setting.
